webvars цикл остановлен. Нет доступа в Интернет "РЕШЕНО НА 50%"
Yashalta
Сообщение Yashalta »
Пытаюсь установить "MD" на Debian 10 по этой инструкции https://kb.mjdm.ru/kak-ustanovit-majordomo-na-linux/
Все вроде встало, но webvars цикл остановлен. и Нет доступа в Интернет
Я попробовал посмотреть, что мешает жить...
sudo php /var/www/html/cycle.php
вывод:
[sudo] password for zerg:
Connecting to database...
CONNECTED TO DB
Checking modules.
Installing settings ... OK
Installing objects ... OK
Installing devices ... OK
Installing actions_log ... OK
Installing app_mediabrowser ... OK
Installing app_player ... OK
Installing blockly_code ... OK
Installing classes ... OK
Installing commands ... OK
Installing connect ... OK
Installing control_access ... OK
Installing dashboard ... OK
Installing dateselect ... OK
Installing events ... OK
Installing history ... OK
Installing jobs ... OK
Installing layouts ... OK
Installing linkedobject ... OK
Installing locations ... OK
Installing market ... OK
Installing master ... OK
Installing methods ... OK
Installing myblocks ... OK
Installing patterns ... OK
Installing pinghosts ... OK
Installing plans ... OK
Installing properties ... OK
Installing pvalues ... OK
Installing saverestore ... OK
Installing scenes ... OK
Installing scripts ... OK
Installing security_rules ... OK
Installing shoutbox ... OK
Installing shoutrooms ... OK
Installing soundfiles ... OK
Installing system_errors ... OK
Installing terminals ... OK
Installing textfiles ... OK
Installing thumb ... OK
Installing users ... OK
Installing xray ... OK
Clearing the cache.
Removing ThisComputer. (object 7) REMOVED 318
Removing ThisComputer.cycle_connectRun (object 7) REMOVED 310
Removing ThisComputer.cycle_execsRun (object 7) REMOVED 316
Removing ThisComputer.cycle_mainRun (object 7) REMOVED 315
Removing ThisComputer.cycle_phistoryRun (object 7) REMOVED 311
Removing ThisComputer.cycle_pingRun (object 7) REMOVED 314
Removing ThisComputer.cycle_schedulerRun (object 7) REMOVED 313
Removing ThisComputer.cycle_statesRun (object 7) REMOVED 317
Removing ThisComputer.cycle_websocketsRun (object 7) REMOVED 312
Starting ./scripts/cycle_wscache.php ...
11:24:08 Starting thread: exec php -q ./scripts/cycle_wscache.php --params "a:0:{}" > /dev/null 2>&1
OK
Starting ./scripts/cycle_main.php ...
11:24:08 Starting thread: exec php -q ./scripts/cycle_main.php --params "a:0:{}" > /dev/null 2>&1
OK
Starting ./scripts/cycle_connect.php ...
11:24:08 Starting thread: exec php -q ./scripts/cycle_connect.php --params "a:0:{}" > /dev/null 2>&1
OK
Starting ./scripts/cycle_websockets.php ...
11:24:08 Starting thread: exec php -q ./scripts/cycle_websockets.php --params "a:0:{}" > /dev/null 2>&1
OK
Starting ./scripts/cycle_scheduler.php ...
11:24:08 Starting thread: exec php -q ./scripts/cycle_scheduler.php --params "a:0:{}" > /dev/null 2>&1
OK
Starting ./scripts/cycle_ping.php ...
11:24:08 Starting thread: exec php -q ./scripts/cycle_ping.php --params "a:0:{}" > /dev/null 2>&1
OK
Starting ./scripts/cycle_execs.php ...
11:24:08 Starting thread: exec php -q ./scripts/cycle_execs.php --params "a:0:{}" > /dev/null 2>&1
OK
Starting ./scripts/cycle_states.php ...
11:24:08 Starting thread: exec php -q ./scripts/cycle_states.php --params "a:0:{}" > /dev/null 2>&1
OK
Starting ./scripts/cycle_phistory.php ...
11:24:08 Starting thread: exec php -q ./scripts/cycle_phistory.php --params "a:0:{}" > /dev/null 2>&1
OK
ALL CYCLES STARTED
11:24:09 Closing thread: exec php -q ./scripts/cycle_connect.php --params "a:0:{}" > /dev/null 2>&1
11:24:09 Closing thread: exec php -q ./scripts/cycle_websockets.php --params "a:0:{}" > /dev/null 2>&1
Судя по выводу все "ОК"!
Подскажите, что и где посмотреть, чтобы запустить webvars цикл и получить доступ в интернет!?!?
Хотя, доступ в интернет есть! Я обновил систему и она скачала нужности из
Downloading https://github.com/sergejey/majordomo/archive/master.tar.gz ...
Ниже вставлен скрин, что система обновлена.
Последний раз редактировалось Yashalta Пт апр 10, 2020 3:41 pm, всего редактировалось 1 раз.
Re: webvars цикл остановлен. Нет доступа в Интернет
Варианта 2 есть - или установить модуль вебварс - сейчас он вынесен из системы.
или в классе systemStates - метод checkState - строка 14 убрать его из списка
типа так
$cycles=array('ping'=>'ping');
Но доступ в интернет - это не отсюда - ну при условии что сюда не заглядывали... и ничего ручками не меняли :lol: :!: :idea:
Yashalta
tarasfrompir писал(а): Ср апр 08, 2020 11:40 am Варианта 2 есть - или установить модуль вебварс - сейчас он вынесен из системы.
типа так
Спасибо! Результат смотри ниже!
А, с интернетом куда комать?
Yashalta писал(а): Ср апр 08, 2020 12:07 pm А, с интернетом куда комать?
строку то верни назад -
только в таком виде - $cycles=array('ping'=>'ping');
я ж тебе писал
и вообще можеш вписать сюда все циклы - которые важны для тебя - скажем по устройствам каким или сам посмотриш...
В устройствах онлайн - есть запись
Internet
поменяй в записи хост с тут.бай на 1.1.1.1
А вообще в форуме описание такого действия имеется
viewtopic.php?f=4&t=6767&p=109710&hilit ... et#p109710
viewtopic.php?f=4&t=6889&p=112472&hilit ... et#p112472
Yashalta
tarasfrompir писал(а): Ср апр 08, 2020 12:37 pm ...
Internet
Поменял, попробовал с разными "IP" адресами. Почему то, пишет "Status: Offline"! Хотя если пинговать из терминала то, все "OK"!
И еще вопрос, а как дать права пользователю www-data для выполнения команды ping?
Последний раз редактировалось Yashalta Ср апр 08, 2020 3:19 pm, всего редактировалось 1 раз.
Yashalta писал(а): Ср апр 08, 2020 3:12 pm
Internet
а цикл пинга запущен?
Панель управления - хрей - сервисі - cycle_ping???
Yashalta
tarasfrompir писал(а): Ср апр 08, 2020 3:19 pm а цикл пинга запущен?
Да, запущен!
А как дать права пользователю www-data для выполнения команды ping? Может и в правду у него нет прав на выполнение этой команды?
Yashalta писал(а): Ср апр 08, 2020 3:22 pm
Да, запущен!
Прости - не знаю - я не линуксовод...
Yashalta
Отвечаю для таких как я!
Получая эту ошибку
root@MajorDomo:~# su www-data
This account is currently not available.
Я хотлел дать все необходимые права для выполнения команды "ping" пользователю www-data
НО, ЭТО ДЕЛАТЬ НЕ НУЖНО!!! https://askubuntu.com/questions/486346/ ... ing-to-ssh
Это плохая идея, давать права sudo для www-данных. Если бы Apache предназначался для работы с правами root, у него не было бы своей собственной группы. Делая это, вы создаете огромные дыры в безопасности, потому что оболочка для пользовательских www-данных установлена ​​в /usr/sbin/nologin и установлена ​​по очень веской причине. Вы не должны входить в систему как www-data, это специальный пользователь / группа, используемая веб-сервером, и не предназначенная для обычного использования оболочки!
что было мною сделанно!
В настройках OnLine устройств я поменял с "PING(HOST)" на "WEB PAGE (URL)" и прописал не "IP" адрес а "url" сайта. Пока такое решение! Если кто подскажет в чем проблема, буду благодарен!
Yashalta писал(а): Ср апр 08, 2020 4:26 pm Отвечаю для таких как я!
простите конечно - а вы проверяли правильность написания айпи адреса - не было ли там пробелов или прочей лобуды - поскольку функция пинг - проверяет что вебстраницу - что айпи адрес. И заморочек с ней не возникало уже очень давно... Ну кроме некоторых нюансов... Но все же проверьте айпи - впишите 1.1.1.1 - 8.8.4.4 - 8.8.8.8
В худой конец впишите адрес роутера....
