gps и доступ извне
Re: [Модуль] GPS tracker (app_gpstrack)
samolet писал(а): Пн мар 16, 2020 9:15 am у меня получилось, попробуй вставить код в app_gpstrack.class.php или замени файл целиком он с поправкой
путь C:\_majordomo\htdocs\modules\app_gpstrack
<?php
* GPS Track
* App_gpstrack
* @package MajorDoMo
* @author Serge Dzheigalo <jey@tut.by> http://smartliving.ru/
* @version 0.2 (wizard, 14:07:59 [Jul 25, 2011])
class app_gpstrack extends module
* app_gpstrack
* Module class constructor
* @access private
function app_gpstrack()
$this->name = "app_gpstrack";
$this->title = "<#LANG_APP_GPSTRACK#>";
$this->module_category = "<#LANG_SECTION_APPLICATIONS#>";
$this->checkInstalled();
* saveParams
* Saving module parameters
* @access public
function saveParams($data = 0)
$p = array();
if (IsSet($this->id)) {
$p["id"] = $this->id;
if (IsSet($this->view_mode)) {
$p["view_mode"] = $this->view_mode;
if (IsSet($this->edit_mode)) {
$p["edit_mode"] = $this->edit_mode;
if (IsSet($this->data_source)) {
$p["data_source"] = $this->data_source;
if (IsSet($this->tab)) {
$p["tab"] = $this->tab;
return parent::saveParams($p);
* getParams
* Getting module parameters from query string
* @access public
function getParams()
global $id;
global $mode;
global $view_mode;
global $edit_mode;
global $data_source;
global $tab;
if (isset($id)) {
$this->id = $id;
if (isset($mode)) {
$this->mode = $mode;
if (isset($view_mode)) {
$this->view_mode = $view_mode;
if (isset($edit_mode)) {
$this->edit_mode = $edit_mode;
if (isset($data_source)) {
$this->data_source = $data_source;
if (isset($tab)) {
$this->tab = $tab;
* Run
* Description
* @access public
function run()
@Define('DEF_ACTION_TYPE_OPTIONS', '1=' . LANG_GPSTRACK_ACTION_ENTERING . '|0=' . LANG_GPSTRACK_ACTION_LEAVING . '|2=' . LANG_GPSTRACK_ACTION_ENTERING_OR_LEAVING); // options for 'ACTION_TYPE'
global $session;
$out = array();
if ($this->action == 'admin') {
$this->admin($out);
$this->usual($out);
if (IsSet($this->owner->action)) {
$out['PARENT_ACTION'] = $this->owner->action;
if (IsSet($this->owner->name)) {
$out['PARENT_NAME'] = $this->owner->name;
$out['VIEW_MODE'] = $this->view_mode;
$out['EDIT_MODE'] = $this->edit_mode;
$out['MODE'] = $this->mode;
$out['ACTION'] = $this->action;
$out['DATA_SOURCE'] = $this->data_source;
$out['TAB'] = $this->tab;
if (IsSet($this->device_id)) {
$out['IS_SET_DEVICE_ID'] = 1;
if (IsSet($this->location_id)) {
$out['IS_SET_LOCATION_ID'] = 1;
if (IsSet($this->user_id)) {
$out['IS_SET_USER_ID'] = 1;
if (IsSet($this->script_id)) {
$out['IS_SET_SCRIPT_ID'] = 1;
if ($this->single_rec) {
$out['SINGLE_REC'] = 1;
$this->data = $out;
$p = new parser(DIR_TEMPLATES . $this->name . "/" . $this->name . ".html", $this->data, $this);
$this->result = $p->result;
* BackEnd
* Module backend
* @access public
function admin(&$out)
$this->getConfig();
$out['MAPPROVIDER'] = $this->config['MAPPROVIDER'];
$out['MAPTYPE'] = $this->config['MAPTYPE'];
$out['MAX_ACCURACY'] = $this->config['MAX_ACCURACY'];
$out['AUTO_OPTIMIZE'] = (int)$this->config['AUTO_OPTIMIZE'];
$out['KEEP_HISTORY'] = (int)$this->config['KEEP_HISTORY'];
$out['API_KEY'] = $this->config['API_KEY'];
if ($this->view_mode == 'update_settings') {
global $mapprovider;
$this->config['MAPPROVIDER'] = $mapprovider;
global $maptype;
$this->config['MAPTYPE'] = $maptype;
global $max_accuracy;
$this->config['MAX_ACCURACY'] = $max_accuracy;
global $api_key;
$this->config['API_KEY'] = $api_key;
$this->config['AUTO_OPTIMIZE'] = gr('auto_optimize', 'int');
$this->config['KEEP_HISTORY'] = gr('keep_history', 'int');
$this->saveConfig();
if ($this->config['AUTO_OPTIMIZE']) {
subscribeToEvent($this->name, 'HOURLY');
$this->redirect("?data_source=gpsoptions&ok=1");
if ($_GET['ok']) {
$out['OK'] = 1;
if ($this->data_source == 'preview' || gr('ajax') || $this->ajax) {
$this->usual($out);
return;
if (isset($this->data_source) && !$_GET['data_source'] && !$_POST['data_source']) {
$out['SET_DATASOURCE'] = 1;
if ($this->data_source == 'gpslog' || $this->data_source == '') {
if ($this->view_mode == '' || $this->view_mode == 'search_gpslog') {
$this->search_gpslog($out);
if ($this->view_mode == 'edit_gpslog') {
$this->edit_gpslog($out, $this->id);
if ($this->view_mode == 'delete_gpslog') {
$this->delete_gpslog($this->id);
$this->redirect("?data_source=gpslog");
if ($this->data_source == 'gpslocations') {
if ($this->view_mode == '' || $this->view_mode == 'search_gpslocations') {
$this->search_gpslocations($out);
if ($this->view_mode == 'edit_gpslocations') {
$this->edit_gpslocations($out, $this->id);
if ($this->view_mode == 'delete_gpslocations') {
$this->delete_gpslocations($this->id);
$this->redirect("?data_source=gpslocations");
if ($this->data_source == 'gpsdevices') {
if ($this->view_mode == '' || $this->view_mode == 'search_gpsdevices') {
$this->search_gpsdevices($out);
if ($this->view_mode == 'edit_gpsdevices') {
$this->edit_gpsdevices($out, $this->id);
if ($this->view_mode == 'delete_gpsdevices') {
$this->delete_gpsdevices($this->id);
$this->redirect("?data_source=gpsdevices");
if ($this->data_source == 'gpsactions') {
if ($this->view_mode == '' || $this->view_mode == 'search_gpsactions') {
$this->search_gpsactions($out);
if ($this->view_mode == 'edit_gpsactions') {
$this->edit_gpsactions($out, $this->id);
if ($this->view_mode == 'delete_gpsactions') {
$this->delete_gpsactions($this->id);
$this->redirect("?data_source=gpsactions");
* FrontEnd
* Module frontend
* @access public
function usual(&$out)
$this->getConfig();
require(DIR_MODULES . $this->name . '/usual.inc.php');
* gpslog search
* @access public
function search_gpslog(&$out)
require(DIR_MODULES . $this->name . '/gpslog_search.inc.php');
* gpslog edit/add
* @access public
function edit_gpslog(&$out, $id)
require(DIR_MODULES . $this->name . '/gpslog_edit.inc.php');
* gpslog delete record
* @access public
function delete_gpslog($id)
$rec = SQLSelectOne("SELECT * FROM gpslog WHERE ID='$id'");
// some action for related tables
SQLExec("DELETE FROM gpslog WHERE ID='" . $rec['ID'] . "'");
* gpslocations search
* @access public
function search_gpslocations(&$out)
require(DIR_MODULES . $this->name . '/gpslocations_search.inc.php');
* gpslocations edit/add
* @access public
function edit_gpslocations(&$out, $id)
require(DIR_MODULES . $this->name . '/gpslocations_edit.inc.php');
* gpslocations delete record
* @access public
function delete_gpslocations($id)
$rec = SQLSelectOne("SELECT * FROM gpslocations WHERE ID='$id'");
SQLExec("DELETE FROM gpslocations WHERE ID='" . $rec['ID'] . "'");
* gpsdevices search
* @access public
function search_gpsdevices(&$out)
require(DIR_MODULES . $this->name . '/gpsdevices_search.inc.php');
* gpsdevices edit/add
* @access public
function edit_gpsdevices(&$out, $id)
require(DIR_MODULES . $this->name . '/gpsdevices_edit.inc.php');
* gpsdevices delete record
* @access public
function delete_gpsdevices($id)
$rec = SQLSelectOne("SELECT * FROM gpsdevices WHERE ID='$id'");
SQLExec("DELETE FROM gpslog WHERE DEVICE_ID='" . $rec['ID'] . "'");
SQLExec("DELETE FROM gpsdevices WHERE ID='" . $rec['ID'] . "'");
* gpsactions search
* @access public
function search_gpsactions(&$out)
require(DIR_MODULES . $this->name . '/gpsactions_search.inc.php');
* gpsactions edit/add
* @access public
function edit_gpsactions(&$out, $id)
require(DIR_MODULES . $this->name . '/gpsactions_edit.inc.php');
* gpsactions delete record
* @access public
function delete_gpsactions($id)
$rec = SQLSelectOne("SELECT * FROM gpsactions WHERE ID='$id'");
SQLExec("DELETE FROM gpsactions WHERE ID='" . $rec['ID'] . "'");
function optimize_log($verbose = 0) {
set_time_limit(6000);
$tmp=SQLSelectOne("SELECT COUNT(*) as TOTAL FROM gpslog");
$before=(int)$tmp['TOTAL'];
$records = SQLSelect("SELECT gpslog.ID, gpslog.DEVICEID, gpslog.LOCATION_ID, gpsdevices.ID AS GPS_DEVICE_ID FROM gpslog LEFT JOIN gpsdevices ON gpslog.DEVICE_ID=gpsdevices.ID ORDER BY gpslog.DEVICEID, gpslog.ADDED DESC");
DebMes("Staring GPS data optimizing (total: $before)",'gps');
$total = count($records);
for ($i = 1; $i < $total - 1; $i++) {
if (!$records[$i]['GPS_DEVICE_ID']) {
SQLExec("DELETE FROM gpslog WHERE ID=" . $records[$i]['ID']);
continue;
if (!$records[$i]['LOCATION_ID']) continue;
if ($records[$i]['LOCATION_ID'] == $records[$i + 1]['LOCATION_ID'] && $records[$i]['LOCATION_ID'] == $records[$i - 1]['LOCATION_ID']
&& $records[$i]['GPS_DEVICE_ID'] == $records[$i + 1]['GPS_DEVICE_ID'] && $records[$i]['GPS_DEVICE_ID'] == $records[$i - 1]['GPS_DEVICE_ID']
if ($verbose && $i % 200 == 0) {
echo ".";
echo str_repeat(' ', 1024);
flush();
flush();
SQLExec("OPTIMIZE TABLE `gpslog`");
$after=(int)$tmp['TOTAL'];
DebMes("Finished GPS data optimizing (total: $after)",'gps');
function processSubscription($event_name, $details = '')
if ($event_name == 'HOURLY') {
$this->getConfig();
if ($this->config['KEEP_HISTORY']) {
SQLExec("DELETE FROM gpslog WHERE ADDED<'".date('Y-m-d H:i:s',(time()-$this->config['KEEP_HISTORY']*24*60*60))."'");
if ($this->config['AUTO_OPTIMIZE'] && ((int)date('H')) == 3) {
$this->optimize_log();
* Install
* Module installation routine
* @access private
function install($data = '')
parent::install();
addClass('GPSLocations');
addClassMethod('GPSLocations', 'userEntered', '//$params["USER_OBJECT"]' . "\n");
addClassMethod('GPSLocations', 'userLeft', '//$params["USER_OBJECT"]' . "\n");
addClassProperty('GPSLocations', 'locationTitle');
addClassProperty('GPSLocations', 'latestVisit');
addClassMethod('Users', 'enteredLocation', '//$params["LOCATION_OBJECT"], $params["LOCATION"]' . "\n");
addClassMethod('Users', 'leftLocation', '//$params["LOCATION_OBJECT"], $params["LOCATION"]' . "\n");
* Uninstall
* Module uninstall routine
* @access public
function uninstall()
SQLExec('DROP TABLE IF EXISTS gpslog');
SQLExec('DROP TABLE IF EXISTS gpslocations');
SQLExec('DROP TABLE IF EXISTS gpsdevices');
SQLExec('DROP TABLE IF EXISTS gpsactions');
parent::uninstall();
* dbInstall
* Database installation routine
* @access private
function dbInstall($data)
gpslog - Log
gpslocations - Locations
gpsdevices - Devices
gpsactions - Actions
$data = <<<EOD
gpslog: ID int(10) unsigned NOT NULL auto_increment
gpslog: ADDED datetime
gpslog: LAT float DEFAULT '0' NOT NULL
gpslog: LON float DEFAULT '0' NOT NULL
gpslog: ALT float DEFAULT '0' NOT NULL
gpslog: PROVIDER varchar(30) NOT NULL DEFAULT ''
gpslog: SPEED float DEFAULT '0' NOT NULL
gpslog: BATTLEVEL int(3) NOT NULL DEFAULT '0'
gpslog: CHARGING int(3) NOT NULL DEFAULT '0'
gpslog: DEVICEID varchar(255) NOT NULL DEFAULT ''
gpslog: DEVICE_ID int(10) NOT NULL DEFAULT '0'
gpslog: LOCATION_ID int(10) NOT NULL DEFAULT '0'
gpslog: ACCURACY float DEFAULT '0' NOT NULL
gpslog: INDEX (DEVICE_ID)
gpslog: INDEX (LOCATION_ID)
gpslocations: ID int(10) unsigned NOT NULL auto_increment
gpslocations: TITLE varchar(255) NOT NULL DEFAULT ''
gpslocations: LINKED_OBJECT varchar(255) NOT NULL DEFAULT ''
gpslocations: LAT float DEFAULT '0' NOT NULL
gpslocations: LON float DEFAULT '0' NOT NULL
gpslocations: RANGE float DEFAULT '0' NOT NULL
gpslocations: VIRTUAL_USER_ID int(10) NOT NULL DEFAULT '0'
gpslocations: IS_HOME int(3) NOT NULL DEFAULT '0'
gpsdevices: ID int(10) unsigned NOT NULL auto_increment
gpsdevices: TITLE varchar(255) NOT NULL DEFAULT ''
gpsdevices: USER_ID int(10) NOT NULL DEFAULT '0'
gpsdevices: LAT varchar(255) NOT NULL DEFAULT ''
gpsdevices: LON varchar(255) NOT NULL DEFAULT ''
gpsdevices: UPDATED datetime
gpsdevices: DEVICEID varchar(255) NOT NULL DEFAULT ''
gpsdevices: TOKEN varchar(255) NOT NULL DEFAULT ''
gpsdevices: HOME_DISTANCE int(10) NOT NULL DEFAULT '0'
gpsdevices: INDEX (USER_ID)
gpsactions: ID int(10) unsigned NOT NULL auto_increment
gpsactions: LOCATION_ID int(10) NOT NULL DEFAULT '0'
gpsactions: USER_ID int(10) NOT NULL DEFAULT '0'
gpsactions: ACTION_TYPE int(255) NOT NULL DEFAULT '0'
gpsactions: SCRIPT_ID int(10) NOT NULL DEFAULT '0'
gpsactions: CODE text
gpsactions: LOG text
gpsactions: EXECUTED datetime
gpsactions: INDEX (LOCATION_ID)
gpsactions: INDEX (USER_ID)
EOD;
parent::dbInstall($data);
$indexes=array('gpslog'=>array('DEVICE_ID','LOCATION_ID'));
foreach($indexes as $indexTable=>$v) {
foreach($v as $indexColumn) {
$indexCheck=SQLSelectOne("SELECT COUNT(1) IndexIsThere FROM INFORMATION_SCHEMA.STATISTICS WHERE table_schema=DATABASE() AND table_name='$indexTable' AND index_name='$indexColumn';");
if (!$indexCheck['IndexIsThere']) {
SQLExec("CREATE INDEX $indexColumn ON $indexTable($indexColumn);");
* TW9kdWxlIGNyZWF0ZWQgSnVsIDI1LCAyMDExIHVzaW5nIFNlcmdlIEouIHdpemFyZCAoQWN0aXZlVW5pdCBJbmMgd3d3LmFjdGl2ZXVuaXQuY29tKQ==
файл в вашем архиве совпадает с файлом Сергея с гитхаба app_gpstrack.class.php
в 421 строке
код echo "."; точно такой, как у Сергея. правок не видно
samolet
Сообщение samolet »
повнимательней, возможно строчкой ошибся смотрите рядом
samolet писал(а):повнимательней, возможно строчкой ошибся смотрите рядом
Что внимательней? Файл байт в байт совпадает, неужели вы думаете, что я глазами сверял? Этот модуль очень важен для меня и мне очень интересны его доработки.
samolet
Сообщение samolet »
ну и хорошо, там добавлен кусок кода взятый на одной из веток нашего форума, если хочешь найти код то кури ветки с иематикой
ну мне вот тоже было интересно, какое изменение починило проблему, а сравнив файлы ни в одном байте отличий найдено не было.
значит и проблема была у вопрошающего в другом ...
samolet писал(а):ну и хорошо, там добавлен кусок кода взятый на одной из веток нашего форума, если хочешь найти код то кури ветки с иематикой
Ткните меня носом в свой код, нету у меня веток с иематикой.
Человек же будет думать, что у него код отличается от стандарта и обновляться не будет
samolet
Сообщение samolet »
ну капец, ну неужели нельзя просто в поиске забить нужные слова,,,,, вот страничка по которой сам все сделал, после исправления начал работать код выше, его я и прислал(рабочий) можете в айдевайс поправить ниже ссылка, но зачем если все заработало
viewtopic.php?f=5&t=4930&p=112458&hilit ... hp#p112458
samolet писал(а): Вт мар 17, 2020 7:32 pm ну капец, ну неужели нельзя просто в поиске забить нужные слова,,,,, вот страничка по которой сам все сделал, после исправления начал работать код выше, его я и прислал(рабочий) можете в айдевайс поправить ниже ссылка, но зачем если все заработало
вы не понимаете, что вы пишете? правите у себя айдевайс, а присылаете гпс_трак, ок.
samolet
Сообщение samolet »
xor писал(а): Вт мар 17, 2020 9:09 pm
чет я не понял, пишешь что помогло, я просто поделился управляющим файлом, и все, зачем что то другое??? вот так помогай, потом еще и упреки, досвидание.
samolet писал(а): Вт мар 17, 2020 9:41 pm
вы вводите людей в заблуждение. досвидание
