[Модуль] KodExplorer (kodexplorer)
В маркет добавлен новый модуль KodExplorer
Это файловый редактор с кучей функций. За основу взят проект https://github.com/kalcaddle/KodExplorer
Возможности:
Use experience like operating system, Rich context menu and toolbar, drag and drop, shortcut keys......
Available in more than 40 languages.
File Manage
All operations with files and folders on a remote server(copy,cute,paste,move,remove,upload,create folder/file,rename,etc.)
Multi-User support,custom role group.
Flexible configuration of access rights,file types restriction, user - interface and other
Clipboard: copy, cut, paste, clear
Selectable files & folders support (mouse click & Ctrl & Shift & words & Keyboard shortcuts)
Keyboard shortcuts: delete deletion, ctrl+A select, ctrl+C replication, ctrl+X splicing, up/down/left/right/home/end etc.
Multiple actions support for selected files & folders: move,copy,cute,remove,rename,open,archive,delete,download etc.
Double or single click setup to open files & folders
Filetree: allow to open and display multiple subfolders at a time
Implemented natural sorting on the client-side
List,Icons and Split view;
Move/Copy/Clone/Delete files with Drag & Drop
Share files or folder to others.
Add folder to your favorites
Calculate directory sizes
Thumbnails for image files
Normalizer:UTF-8 Normalizer of file-name and file-path etc.
Muti Charset support, in a variety of circumstances garbled solution;Sanitizer of file-name and file-path etc.
Multiple & chunked uploads support,
Background file upload with Drag & Drop HTML5 support;Folder upload with Chrome, Firefox and Edge
Upload form URL (or list)
Direct extraction to the current working directory (you do not want - to create a folder)
Search: search by filename & file contents
File exclusion based on name
Copy direct file URL
Archives create/extract/preview (zip, rar, 7z, tar, gzip, tgz)
Quicklook, preview for common file types; image file,text file,pdf,swf,document file etc.
Video and audio player relying on web browser capabilities
Editor
Syntax highlighting for over 120 languages
Multiple label, Drag & Drop the label.
Over 15 themes,Choose your favorite programming style
Web development: HTML/JS/CSS editor with Emmet integrated
Automatic indent and outdent;Line wrapping;Code folding
Multiple cursors and selections;(Middle key select;Ctrl+Command+G)
Autocomplete.
Fully customizable key bindings including vim and Emacs modes
Search and replace with regular expressions;Highlight matching parentheses
Toggle between soft tabs and real tabs
Displays hidden characters
Drag and drop text using the mouse
Live syntax checker (JavaScript/CoffeeScript/CSS/XQuery/HTML/PHP etc.)
Cut, copy, and paste functionality
Markdown support.(live preview;convert to html etc.)
Format: JavaScript/CSS/HTML/JSON/PHP etc.
Cross-platform, even on mobile devices
Easy to integrate with other systems
Developed by kod itself, this is a nice try.
Последний раз редактировалось directman66 Ср июн 13, 2018 1:53 pm, всего редактировалось 1 раз.
Re: Re: [Модуль] KodExplorer
Кстати, встроен Adminer, в котором можно работать с mysql. Отлично заменяет phpmyadmin
ILGAS
Сообщение ILGAS »
Крутяк, целая операционка).
Думал, может есть сканер сетевых ресурсов, но чето не нашел )
nightwind
Сообщение nightwind »
удаление не работает. через путь все равно можно зайти)
Файла? Модуля?
nightwind
Удаление модуля. Проходит, пишет все ок. Но заходит в него, если прописать в браузере путь к нему вручную. Файлы все после удаления модуля на месте.
Попробовал, при удалении модуля удалились все его папки. Linux.
xxxShahxxx
Сообщение xxxShahxxx »
Добрый день.
Народ, а теперь, для "самых маленьких" Как эта штука заводится? Нужны логин и пароль. Залез на сайт разработчиков, а где логиниться то там? Или я слепой?
Или там вообще другая логика? Нужно сначала установить данную свистелку-перделку на управляемую машину, а там уже будет эффект "Вау!"?
ILGAS
Сообщение ILGAS »
xxxShahxxx писал(а): Ср июл 25, 2018 11:56 am Добрый день.
Просто устанавливаешь модуль из маркета и вот тебе "Вау!" эффект.
