Оборудование для "Умного дома"
Приветствую всех!!!
Предлагаю в данном топике обсуждать вопросы для покупке оборудования для использования с системой "MajorDoMo".
Есть возможность заказать по выгодной цене следующее оборудование:
1. Ip power 9212 delux
описание и примеры использования - http://www.ab-log.ru/smart-house/ethernet/ippower-9212
2. ip power 9223K (IP Power 9258HP-в корпусе)
пример использования - http://smartliving.ru/Main/DevIpPower9223
3. ip camera HD формата
Характеристики:
1. Tri-Mode Camera (MPG4-1/MPEG4-2/M-Jpeg)
2. Advance Motion detection trigger AVI /Jpeg save on FTP / SD card or Email
3. 3 layers (Admin, Operator, and User) Password protected
4. Resolution from CIF 352x192 up to HD 1280x720P
5. Supports NTP protocol to get correct time schedule.
6. 1/2.5” Advance CMOS sensor, with highly sensibility for quick response insufficient lighting.
7. Infrared for Indoor / Outdoor use
8. Water Resistant Design
9. Supports HTTP CGI command set. Easy for system integration
10. IP Service Search utility, to find the IP Kamera on internet with ease
11. Watchdog / Event log design
12. Adjustable frame-rate, bit-rate, rate-control type, quality factor for best image quality and speed.
13. Supports date and time marking on the captured video, and also inserted streamed data.
14. Measured End-to-End latency is less than 150ms
15. Supports adjustable backlight, brightness, contrast, saturation & sharpness
16. TV Output capabilities
17. Automatic alarm recording buffer
18. CNT Technology – Just Plug and Play no need to port forward
19. EPTZ – Electronic Pan, Tilt, and Zoom
20. 2BG SD Memory Storage – Add convenience and storage
21. Scheduler recording capabilities
22. Email Capabilities (Supports Gmail, Yahoo, & Hotmail)
23. Alarm Recording Buffer
24. Supports: HTTP Web Server (HTTP), SSL, FTP client, SMTP client, NTP client, DHCP client, UPnP client, RTSP over UDP, RTP
25. RSS Notification
26. Net drive Capabilities - For storage to local network computer
27. Time Stamp and OSD features
4. 1-wire адаптер USB9097
пример использования - http://smartliving.ru/Main/OnewireWindows
Минимальный заказ IP оборудования 5 единиц, поэтому и предлагается заказ обобщить для тех кто желает присоединиться.
Предварительно заявки можете оставлять здесь на форуме или на сайте http://находятвсе.рф/
В ближайшее время там будут выставлены цены.
Характеристики:
Re: Оборудование для "Умного дома"
Вот ещё оборудование для умного дома.
- Очень даже ничего так.
http://www.kernelchip.ru/Laurent.php - Laurent.jpg (62.78 КБ) 27754 просмотра
- Хорошо, но дорого. Зато, кажется, оригинальное.
http://amperka.ru/ - A-UNO.png (162.35 КБ) 27754 просмотра
- Ещё есть мелочёвка от Masterkit. Типа термометров и USB реле. Есть даже контроллеры какие-то.
http://www.masterkit.ru/ - mp707.jpg (15.57 КБ) 27754 просмотра
Спасибо,Alex писал(а):Вот ещё оборудование для умного дома.
"Лоран" оказался интересной железкой с виду. Гибрид ардуины и 9223K. Выглядит кстати посолиднее и есть исполнение в корпусе, что "+"
Если его можно будет прикрутить к системе, то думаю мой выбор на нем остановиться. После праздников надо будет параметры сравить.
В Амперке брал свою Ардуину как раз под этот проект, взял в наборе Y. Очень доволен
Отношения к обеим компаниям не имею
- sergejey
- Site Admin
Если б в этой штуке была возможность инициировать соединение с сервером при изменении состояния датчиков, то вообще было бы здорово... а так там есть режим "сторож", но он требует постоянно открытого соединения сервера с железякой, что по мне так не удобно. Состояние датчиков можно опрашивать через модуль Веб-переменные (благо он сейчас и авторизацию поддерживае), но тоже не супер-вариант.shurlin писал(а):"Лоран" оказался интересной железкой с виду. Гибрид ардуины и 9223K. Выглядит кстати посолиднее и есть исполнение в корпусе, что "+"
Ну а вообще хорошие "железки", если лень заморачиваться с Arduino
Железа должно быть много
хорошего и разного. В одном месте Arduino (со своими задачами), в другом — Лоран (со своими). А может быть разработчики учтут пожелания трудящихся и добавят возможность инициировать соединения.
Интересно, если сравнить 9223К и Лоран, то что лучше (хуже) и чем?
Нет, нам не лень. Только вопрос. Есть работающий код для UNO+Ethernet или надо будет изобрести велосипед? Видел примеры в Интернете — вроде разобраться можно. Но хотелось бы вариант - поправил логику датчиков, залил и всё работает.
В принципе работающий вариант есть на сайте, но я его все равно допиливал "напильником" очень жестко и до сих пор не почистил код для Ардуины. Навыки в программировании очень пригодились.Alex писал(а): Нет, нам не лень. Только вопрос. Есть работающий код для UNO+Ethernet или надо будет изобрести велосипед? Видел примеры в Интернете — вроде разобраться можно. Но хотелось бы вариант - поправил логику датчиков, залил и всё работает.
По исходникам на сайте, там подключались старые либы и как минимум пришлось докачать новый OneWire.h и DallasTemperature.h
Опять же мне не нравилось что 1 датчик температуры занимал весь канал и весь смысл 1-wire терялся, так что пришлось немного поколдовать чтобы посадить все на 1 линию
Так что велосипед изобретать не придется, но собирать-разбирать его надо уметь.
Да, у меня ардуина без эзернета, так что может быть в других исходниках все норм.
shurlin писал(а):В принципе работающий вариант есть на сайте, но я его все равно допиливал "напильником" очень жестко и до сих пор не почистил код для Ардуины. Навыки в программировании очень пригодились.Alex писал(а): Нет, нам не лень. Только вопрос. Есть работающий код для UNO+Ethernet или надо будет изобрести велосипед? Видел примеры в Интернете — вроде разобраться можно. Но хотелось бы вариант - поправил логику датчиков, залил и всё работает.
Напишите свой вариант реализации 1-wire сети с использованием arduino, другим использующим этот вариант будет думаю полезно...Опять же мне не нравилось что 1 датчик температуры занимал весь канал и весь смысл 1-wire терялся, так что пришлось немного поколдовать чтобы посадить все на 1 линию
Alex писал(а):Железа должно быть многохорошего и разного. В одном месте Arduino (со своими задачами), в другом — Лоран (со своими). А может быть разработчики учтут пожелания трудящихся и добавят возможность инициировать соединения.
Если сравнивать 9223К и Лоран, то в управлении с системы удобней 9223К, но в нем использование только реле, в Лоран есть входы выходы, но как писал Сергей есть и свои минусы.
Если смотреть по функционалу в сторону Лоран, то я все таки выбрал бы ip power 9212 delux? В скором времени появится у меня данный девайс.....после проверки всех возможностей будет статья по использованию его с системой....
Как я уже писал, если будут желающие в железе фирмы aviosys (9223к, 9212 delux), то сможем организовать приобретение напрямую из китая, цены будут ниже чем на сайте aviosys.ru
Ethernet Thermometer,8 channels Tx sensors,Multipoint-Temp system (1W340A_T8).
Product Information
1. Features
(1) Equipment support the standard 1-Wire agreement, support 1-Wire digital temperature sensor DS18B20, temperature resolution 0.0625 degree;
support IIC digital temperature sensor FM75 (Dx sensor). But, both cannot be used at the same time.
(2). Equipment can connect up 12 DS18B20 temperature probe, Or connect up 8 of IIC probe .
(3). Software support Windows series, and support real-time temperature display, log records, curve shows, MSN remote view data, E-mail alarm etc. Function
(4). Equipment support UDP, in which the TCP protocol, either as a server but also as a client. Server maximum can support five units (client) at the same time. UDP only support the client
(5). Equipment LAN module can be configured
(6). Equipment support reset function, when IP changes or forget the IP, you can long press "reset keys” 3 s can be restored to the default value
(7) At present , our software only support local area network , if you want to use this device on internet , you need to used some software (such as PeanutHull) to self-configuring .
The default LAN basic configuration
(1) device ipaddress:192.168.1.188
(2) device netmask:255.255.255.0
(3) device gateway:192.168.1.2
(4) host ipaddress:192.168.1.16
(5) connection type: tcp
(6) host port:16000
The following is cannot a configuration items:
As a TCP server, equipment listening port is 5200.
As a TCP client, equipment local port is 40000.
As UDP client, equipment local port is 30000.
2. Electronic Parameters
(1). The rated voltage: + 5 V
(2). Rated current: about 130mA
(3). Rated power: 550 mW
(4) Temperature Accuracy: Tx probe :+/-1.5degrees Celsius ;
Dx probe : ±0.5degrees Celsius
(5). 1-Wire line length: (theory) 50 m, (suggest) < 5 m
(6). The probe number: (the biggest quantities) 12 pcs (Dx probe)
(the biggest quantities) 8 pcs (Tx probe)
Product Information
1. Features
(6) host port:16000
Очень интересно. Было бы здорово, если бы вы выложили описание своих изысканий в виде небольшой статьи с пояснениями для «чайников». Ещё интересно, как у вас организована связь с Ардуино без езернета.По исходникам на сайте, там подключались старые либы и как минимум пришлось докачать новый OneWire.h и DallasTemperature.h
