woow
Сообщение woow »
вчера получил onoff Controller
но пока не получается его привязать, тоже каждую секунду его бадать или как?
Feb 09 20:46:13 dom npm[14292]:   zigbee2mqtt:warn 2/9/2019, 8:46:13 PM Device with modelID 'undefined' is not supported.
Feb 09 20:46:13 dom npm[14292]:   zigbee2mqtt:warn 2/9/2019, 8:46:13 PM Please see: https://koenkk.github.io/zigbee2mqtt/how_tos/how_to_support_new_devices.html
Feb 09 20:46:25 dom npm[14292]:   zigbee2mqtt:warn 2/9/2019, 8:46:25 PM Message without device!
Feb 09 20:46:51 dom npm[14292]:   zigbee2mqtt:warn 2/9/2019, 8:46:51 PM Message without device!
Feb 09 20:46:51 dom npm[14292]:   zigbee2mqtt:info 2/9/2019, 8:46:51 PM Device incoming...
Feb 09 20:46:51 dom npm[14292]:   zigbee2mqtt:info 2/9/2019, 8:46:51 PM MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"type":"pairing","message":"device incoming"}'
Raspberry Pi 3B+
SrFatCat
Сообщение SrFatCat »
directman66 писал(а): Сб фев 09, 2019 5:38 pm покажите, что лежит в таблицах zigbee2mqtt и zigbee2mqtt_devices
zigbee2mqtt_devices_listSPOILER_SHOW
localhost/		http://192.168.0.60/phpmyadmin/server_sql.php?db=&token=1ae6248f1ac19c724c4b660cdd1c4f04
 Отображение строк 0 - 24 (212 всего, Запрос занял 0.0015 сек.)
SELECT * FROM db_terminal.zigbee2mqtt_devices_list
ID	zigbeeModel	model	vendor	type	description	extend	supports	fromZigbee	toZigbee
1	lumi.light.aqcn02	ZNLDP12LM	Xiaomi	bulb	Aqara smart LED bulb	generic.light_onoff_brightness_colortemp		fz.light_brightness, fz.light_color_colortemp, fz....
2	lumi.sensor_switch	WXKG01LM	Xiaomi	remote	MiJia wireless switch		single, double, triple, quadruple, many, long, lon...	fz.xiaomi_battery_3v, fz.WXKG01LM_click, fz.ignore...
3	lumi.sensor_switch.aq2	WXKG11LM	Xiaomi	remote	Aqara wireless switch		single, double click (and triple, quadruple, hold,...	 fz.xiaomi_battery_3v, fz.WXKG11LM_click, fz.ignor...
4	lumi.remote.b1acn01\u0000\u0000\u0000\u0000\u0000\...	WXKG11LM	Xiaomi	remote	Aqara wireless switch		single, double click (and triple, quadruple, hold,...	 fz.xiaomi_battery_3v, fz.WXKG11LM_click, fz.ignor...
5	lumi.sensor_switch.aq3	WXKG12LM	Xiaomi	remote	Aqara wireless switch (with gyroscope)		single, double, shake, hold, release	fz.xiaomi_battery_3v, fz.WXKG12LM_action_click_mul...
6	lumi.sensor_swit	WXKG12LM	Xiaomi	remote	Aqara wireless switch (with gyroscope)		single, double, shake, hold, release	fz.xiaomi_battery_3v, fz.WXKG12LM_action_click_mul...
7	lumi.remote.b186acn01\u0000\u0000\u0000	WXKG03LM	Xiaomi	remote	Aqara single key wireless wall switch		single click
8	lumi.sensor_86sw1\u0000lu	WXKG03LM	Xiaomi	remote	Aqara single key wireless wall switch		single click
9	lumi.sensor_86sw2.es1	WXKG02LM	Xiaomi	remote	Aqara double key wireless wall switch		left, right and both click
10	lumi.sensor_86sw2Un	WXKG02LM	Xiaomi	remote	Aqara double key wireless wall switch		left, right and both click
11	lumi.sensor_86sw2\u0000Un	WXKG02LM	Xiaomi	remote	Aqara double key wireless wall switch		left, right and both click
12	lumi.remote.b286acn01\u0000\u0000\u0000	WXKG02LM	Xiaomi	remote	Aqara double key wireless wall switch		left, right and both click
13	lumi.ctrl_neutral1	QBKG04LM	Xiaomi	remote	Aqara single key wired wall switch		on/off
14	lumi.ctrl_ln1	QBKG11LM	Xiaomi	remote	Aqara single key wired wall switch		on/off, power measurement
15	lumi.ctrl_ln1.aq1	QBKG11LM	Xiaomi	remote	Aqara single key wired wall switch		on/off, power measurement
16	lumi.ctrl_neutral2	QBKG03LM	Xiaomi	remote	Aqara double key wired wall switch		release/hold, on/off
17	lumi.ctrl_ln2.aq1	QBKG12LM	Xiaomi	remote	Aqara double key wired wall switch		on/off, power measurement
18	lumi.sens	WSDCGQ01LM	Xiaomi	sensor	MiJia temperature & humidity sensor		temperature and humidity
19	lumi.weather	WSDCGQ11LM	Xiaomi	sensor	Aqara temperature, humidity and pressure sensor		temperature, humidity and pressure
20	lumi.sensor_motion	RTCGQ01LM	Xiaomi	sensor	MiJia human body movement sensor		occupancy
21	lumi.sensor_motion.aq2	RTCGQ11LM	Xiaomi	sensor	Aqara human body movement and illuminance sensor		occupancy and illuminance
22	lumi.sensor_magnet	MCCGQ01LM	Xiaomi	sensor	MiJia door & window contact sensor		contact
23	lumi.sensor_magnet.aq2	MCCGQ11LM	Xiaomi	sensor	Aqara door & window contact sensor		contact
24	lumi.sensor_wleak.aq1	SJCGQ11LM	Xiaomi	sensor	Aqara water leak sensor		water leak true/false
25	lumi.sensor_cube.aqgl01	MFKZQ01LM	Xiaomi	remote	Mi/Aqara smart home cube		shake, wakeup, fall, tap, slide, flip180, flip90, ...
zigbee2mqttSPOILER_SHOW
 Отображение строк 0 - 14 (15 всего, Запрос занял 0.0018 сек.)
ID	TITLE	LOCATION_ID	UPDATED	VALUE	PATH	METRIKA	PATH_WRITE	COMMAND_VALUE	REPLACE_LIST	LINKED_OBJECT	LINKED_PROPERTY	LINKED_METHOD	QOS	RETAIN	CONVERTONOFF	DEV_ID	DISP_FLAG	PAYLOAD_ON	PAYLOAD_OFF	PAYLOAD_TRUE	PAYLOAD_FALSE
1	zigbee2mqtt/bridge/state	0	2019-02-09 16:20:21	online	zigbee2mqtt/bridge/state	state							0	0	0	1	0
2	zigbee2mqtt/AqaraMotion2/illuminance	0	2019-02-09 22:46:20	3	zigbee2mqtt/AqaraMotion2/illuminance	illuminance							0	0	0	2	0
3	zigbee2mqtt/AqaraMotion2/linkquality	0	2019-02-09 22:46:20	21	zigbee2mqtt/AqaraMotion2/linkquality	linkquality							0	0	0	2	0
4	zigbee2mqtt/AqaraMotion2/occupancy	0	2019-02-09 22:46:20		zigbee2mqtt/AqaraMotion2/occupancy	occupancy							0	0	0	2	0
5	zigbee2mqtt/AqaraMotion2	0	2019-02-09 22:46:20	{"illuminance":3,"linkquality":21,"occupancy":fals...	zigbee2mqtt/AqaraMotion2	AqaraMotion2							0	0	0	2	0
6	zigbee2mqtt/bridge/networkmap	0	2019-02-09 16:22:55	raw	zigbee2mqtt/bridge/networkmap	networkmap							0	0	0	1	0
7	zigbee2mqtt/bridge/networkmap/raw	0	2019-02-09 16:22:55	[{"ieeeAddr":"0x00158d0002e277eb","nwkAddr":18497,...	zigbee2mqtt/bridge/networkmap/raw	raw							0	0	0	1	0
8	zigbee2mqtt/AqaraMotion1/illuminance	0	2019-02-09 22:24:16	3	zigbee2mqtt/AqaraMotion1/illuminance	illuminance							0	0	0	3	0
9	zigbee2mqtt/AqaraMotion1/linkquality	0	2019-02-09 22:24:16	13	zigbee2mqtt/AqaraMotion1/linkquality	linkquality							0	0	0	3	0
10	zigbee2mqtt/AqaraMotion1/occupancy	0	2019-02-09 22:24:16		zigbee2mqtt/AqaraMotion1/occupancy	occupancy							0	0	0	3	0
11	zigbee2mqtt/AqaraMotion1/battery	0	2019-02-09 22:24:16	100	zigbee2mqtt/AqaraMotion1/battery	battery							0	0	0	3	0
12	zigbee2mqtt/AqaraMotion1/voltage	0	2019-02-09 22:24:16	3035	zigbee2mqtt/AqaraMotion1/voltage	voltage							0	0	0	3	0
13	zigbee2mqtt/AqaraMotion1	0	2019-02-09 22:24:16	{"illuminance":3,"linkquality":13,"occupancy":fals...	zigbee2mqtt/AqaraMotion1	AqaraMotion1							0	0	0	3	0
14	zigbee2mqtt/AqaraMotion2/battery	0	2019-02-09 22:46:20	100	zigbee2mqtt/AqaraMotion2/battery	battery							0	0	0	2	0
15	zigbee2mqtt/AqaraMotion2/voltage	0	2019-02-09 22:46:20	3045	zigbee2mqtt/AqaraMotion2/voltage	voltage							0	0	0	2	0
zigbee2mqtt_devicesSPOILER_SHOW
 Отображение строк 0 -  2 (3 всего, Запрос занял 0.0013 сек.)
ID	TITLE	ONLINE	MANUFACTURE	DEVICE_NAME	MODEL	TYPE	SELECTTYPE	SELECTVENDOR	LASTPING	IEEEADDR	PARRENTIEEEADDR	LQI	NWKADDR	MANUFID	MANUFNAME	POWERSOURCE	MODELID	STATUS	JOINTIME	DID	D_ID	FIND	LOCATION_ID
1	bridge				cc2531	Coordinator	cc2531			0x00124b001936dbe0			0	0			cc2531	online			MxUIUGddSw1jOyrm	2019-02-09 16:22:55	6
2	AqaraMotion2									AqaraMotion2												2019-02-09 22:46:20	0
3	AqaraMotion1									AqaraMotion1												2019-02-09 22:24:16	0
SrFatCat
woow писал(а): Сб фев 09, 2019 9:51 pm но пока не получается его привязать, тоже каждую секунду его бадать или как?
О! Такая же фигня была со вторым датчиком. Привязывал раз 6. Потом плюнул. Залез в datebase.db и всё вписал руками, благо первый датчик привязался нормально - по его шаблону и вязал.
woow
Сообщение woow »
SrFatCat писал(а): Сб фев 09, 2019 11:05 pm
мммда а этому от куда взять шаблон?
Raspberry Pi 3B+
SrFatCat
woow писал(а): Сб фев 09, 2019 11:20 pm мммда а этому от куда взять шаблон?
Получилось что-то?
Надо, походу, включать отладочный режим и писать Коену
SrFatCat
SrFatCat писал(а): Сб фев 09, 2019 4:19 pm Я правда поменял в .yaml frendly name
Поменял взад. Устройства не появились... Рестарт zigbee2mqtt и MD сделал. Нету ничего кроме, свистка. В MQTT - всё как надо. Устройства исправно постят данные
SrFatCat
А нее... Прочихалось. Появились датчички.
Картинки в них восстановил известным уже образом. Кстати, местоположение у устройств только у меня не сохраняется?
woow
Сообщение woow »
SrFatCat писал(а): Вс фев 10, 2019 8:01 pm А нее... Прочихалось. Появились датчички.
поздравляю
SrFatCat писал(а): Вс фев 10, 2019 8:01 pm Кстати, местоположение у устройств только у меня не сохраняется?
это вы о чём?
Raspberry Pi 3B+
SrFatCat
woow писал(а): Вс фев 10, 2019 11:26 pm поздравляю
Да особо не с чем. Датчики то появились после того как я frendly name вернул на дурацкое ИД, а это не есть гуд. Ну и самое неприятно,
что на карте так ничего и не появилось...
это вы о чём?
Об этом:
Opera Снимок_2019-02-10_232804_192.168.0.60.png (42.88 КБ) 5575 просмотров
Выставляю. Нажимаю сохранить, а там опять select
Вам удалось onoff привязать?
Местоположение на будущее. Его пока не настраивал. Почему у вас пустые SELECTVENDOR и SELECTYPE? На всех устройствах так? Вы же как то выбрали их, чтобы показались картинки.
