Проверим работу пхпмэлера
Создаём сценарий:
* This example shows settings to use when sending via Google's Gmail servers.
//SMTP needs accurate times, and the PHP time zone MUST be set
//This should be done in your php.ini, but this is how to do it if you don't have access to that
//date_default_timezone_set('Etc/UTC');
require_once 'lib/PHPMailer/PHPMailerAutoload.php';
//Create a new PHPMailer instance
$mail = new PHPMailer;
$mail->setLanguage('ru', 'lib/PHPMailer/language/');
//Tell PHPMailer to use SMTP
$mail->isSMTP();
//Enable SMTP debugging
// 0 = off (for production use)
// 1 = client messages
// 2 = client and server messages
$mail->SMTPDebug = 2;
//Ask for HTML-friendly debug output
$mail->Debugoutput = 'html';
//Set the hostname of the mail server
$mail->Host = 'smtp.yandex.com';
//Set the SMTP port number - 587 for authenticated TLS, a.k.a. RFC4409 SMTP submission
$mail->Port = 587;
//Set the encryption system to use - ssl (deprecated) or tls
$mail->SMTPSecure = 'tls';
//Whether to use SMTP authentication
$mail->SMTPAuth = true;
$mail->CharSet = "UTF-8";
//Username to use for SMTP authentication - use full email address
$mail->Username = gg('Sergey.YaMailAddress');
//Password to use for SMTP authentication
$mail->Password =gg('Sergey.YaPassword');
//Set who the message is to be sent from
$mail->setFrom(gg('Sergey.YaMailAddress'), 'Alice');
//Set an alternative reply-to address
//$mail->addReplyTo('replyto@example.com', 'First Last');
//Set who the message is to be sent to
$mail->addAddress('VasyaPupkin@gmail.com', 'Vasya Pupkin'); //VasyaPupkin@gmail.com меняем на реальный адрес кому слать письмо
//Set the subject line
$subj='Второй Текст в кодировке UTF';
$mail->Subject = $subj;
//Read an HTML message body from an external file, convert referenced images to embedded,
//convert HTML into a basic plain-text alternative body
//$mail->msgHTML(file_get_contents('lib\PHPMailer\examples\index.html'), dirname(__FILE__));
//$body=iconv("UTF-8", "WINDOWS-1251", 'тестовая отправка <b>in bold!</b>');
$body='Проба кодировки';
$mail->Body = $body ;
//Replace the plain text body with one created manually
//$mail->AltBody = 'This is a plain-text message body';
//Attach a file
//$mail->addAttachment('c:/myip.txt'); // проверим вложение
//send the message, check for errors
if (!$mail->send()) {
echo "Ошибка почты: " . $mail->ErrorInfo;
echo "Письмо отправлено!";
}Запускаем, анализируем лог на предмет ошибок
