И в список не добавляются?antpino писал(а): Чт апр 18, 2019 5:18 pm данные после обновленияКод: Выделить всё
21:35:58 Array ( [0] => Array ( [NAME] => cookies (1).txt [DATE] => April 18 2019 21:35:48 [SIZE] => 2.77 KB [ERROR] => ) ) 21:35:58 Array ( ) 21:35:58 Array ( [0] => Array ( [0] => Array ( [0] => Array ( [0] => 114139853432710950067 [1] => https://lh4.googleusercontent.com/-_Qlc66v6oxs/AAAAAAAAAAI/AAAAAAAAAAA/ACHi3rfwVW1F76erI5TvjwIJaQwmVX164g/mo/photo.jpg [2] => [3] => Наташа [4] => [5] => [6] => [7] => 0ahUKEwjf5dXb7tnhAhWSLlAKHZppBR8QvDgIBygA ) [1] => Array ( [0] => [1] => Array ( [0] => [1] => 82.7749609 [2] => 52.5055432 ) [2] => 1555550149961 [3] => 16 [4] => Пляжный пер., Алейск, Алтайский край, Россия, 658130 [5] => [6] => RU [7] => 25200000 ) [2] => [3] => [4] => 0ahUKEwjf5dXb7tnhAhWSLlAKHZppBR8Qu4IBCAYoBA [5] => [6] => Array ( [0] => 114139853432710950067 [1] => https://lh4.googleusercontent.com/-_Qlc66v6oxs/AAAAAAAAAAI/AAAAAAAAAAA/ACHi3rfwVW1F76erI5TvjwIJaQwmVX164g/mo/photo.jpg [2] => Наташа [3] => Наташа ) [7] => 1 [8] => [9] => [10] => [11] => [12] => [13] => Array ( [0] => 0 [1] => 48 ) [14] => 1 ) [1] => Array ( [0] => Array ( [0] => 103406670014998417914 [1] => https://lh4.googleusercontent.com/-r9Wh_JsBP4k/AAAAAAAAAAI/AAAAAAAAAMM/GtO9YOxWCY0/photo.jpg [2] => [3] => Ант Пино [4] => [5] => [6] => [7] => 0ahUKEwjf5dXb7tnhAhWSLlAKHZppBR8QvDgIGygA ) [1] => Array ( [0] => [1] => Array ( [0] => [1] => 82.7752391 [2] => 52.5055445 ) [2] => 1555598082710 [3] => 33 [4] => Алейск, Алтайский край, Россия, 658130 [5] => [6] => RU [7] => 25200000 ) [2] => [3] => [4] => 0ahUKEwjf5dXb7tnhAhWSLlAKHZppBR8Qu4IBCBooBQ [5] => [6] => Array ( [0] => 103406670014998417914 [1] => https://lh4.googleusercontent.com/-r9Wh_JsBP4k/AAAAAAAAAAI/AAAAAAAAAMM/GtO9YOxWCY0/photo.jpg [2] => Ант Пино [3] => Ант ) [7] => 0 [8] => [9] => [10] => [11] => [12] => [13] => Array ( [0] => 0 [1] => 62 ) [14] => 3 ) ) [1] => [2] => 0ahUKEwjf5dXb7tnhAhWSLlAKHZppBR8Q8ZABCAE [3] => S4u4XJ-UEZLdwAKa05X4AQ [4] => [5] => [6] => GpUBAB619KYq30fLEqUuJ0FvYKYOkc7zctCJ/I/5nTDdc1xJbRmKJeKpM2qP6oXhi8abdZmaWimVSm4miBypyis2Y8R8+8s0gTRWWmlxJFPH0OD4kwODDxIUbv8JYV/iaMLFbk7YhGO1uzZFvpGYdDBjFF0MYBQnlATmzrD6kvHKQ9Q9/ADqU8/d89sg3k6NBXUDK7gp4x4= [7] => 4 [8] => 1555598155908 ) 21:35:58 Location data : Connection successful, reponse : 200
[Модуль] Google Location
- Eraser
Re: [Модуль] Google Location
Connect ---- Telegram
- Eraser
залил фикс
Вечер добрый! У меня такая же проблема. Обновил до последней версии нечего не поменялось у меня.
Аккаунт надо как то особенно настраивать ?
Обновление у пользователя меняется раз в час.
На фото отметил.
21:05:02 Array
[0] => Array
[id] => 478786206
[name] => cookies
[fullname] => cookies
[image] =>
[address] =>
[timestamp] => 1555611000013
[lat] => 54.7782483
[lon] => 20.6394845
[accuracy] => 16
21:05:02
[null,null,"0ahUKEwjT8pbvqtrhAhUQlosKHW_QC2UQ8ZABCAE","Xsq4XNPLE5CsrgTvoK-oBg",null,null,"GkkAHrX0pj4SLIkFo9mzGA4epxPM+d6dzQgstBeRNOArhiRnpEroaUMxyJTcLR1lq9WAPTBM4X/Jr6RelDjAB3XToYO2AiR4lVEC",1800,1555614302945,[null,[null,[null,20.6394845,54.7782483]
,1555611000013,16,"",null,"RU",7200000]
,"ILrvn5-HutbFtQE"]
- 2019-4-18 20-54-21.jpg (46.85 КБ) 5282 просмотра
- Eraser
зачем добавлять 3 аккаунта, достаточно на телефоне расшарить свое местоположения на один аккаунтEVGENII писал(а): Чт апр 18, 2019 10:11 pm
https://support.google.com/maps/answer/ ... roid&oco=1
на google картах должны быть видны пользователи которые расшарили свое местоположение
Сейчас исправим! Я правильно понял настроить фикцию пердача геоданных?Eraser писал(а): Чт апр 18, 2019 10:18 pmзачем добавлять 3 аккаунта, достаточно на телефоне расшарить свое местоположения на один аккаунтEVGENII писал(а): Чт апр 18, 2019 10:11 pm
СПАСИБО БОЛЬШОЕ! Заработало все отлично!EVGENII писал(а): Чт апр 18, 2019 10:27 pmСейчас исправим! Я правильно понял настроить фикцию пердача геоданных?Eraser писал(а): Чт апр 18, 2019 10:18 pmзачем добавлять 3 аккаунта, достаточно на телефоне расшарить свое местоположения на один аккаунтEVGENII писал(а): Чт апр 18, 2019 10:11 pm
А почему нельзя видеть свой уровень заряда? Как то не удобно создавать ещё один аккаунт и делать его в браузере как основным. чтобы все работало
Круто! подтянулось имя, аватар и уровень заряда телефона.
Но только почему то, только 1 пользователь в списке появился
- Eraser
google не выдает эти данныеZokkiMir писал(а): Чт апр 18, 2019 11:47 pm А почему нельзя видеть свой уровень заряда? Как то не удобно создавать ещё один аккаунт и делать его в браузере как основным. чтобы все работало
