При попытки отредактировать пользователя вылезает это
Error
Details
http://178.19.248.186/admin.php?pd=cGFuZWw6e2FjdGlvbj11c2Vyc30%3Dpz_&md=users&inst=adm&
1048: Column 'IS_ADMIN' cannot be null
UPDATE `users` SET `ID`='6', `USERNAME`='Timur', `NAME`='Тимур', `EMAIL`='vgamaev@yandex.ru', `SKYPE`='', `MOBILE`='', `AVATAR`='', `PASSWORD`='', `IS_ADMIN`=NULL, `IS_DEFAULT`=NULL, `LINKED_OBJECT`='Timur', `HOST`='', `ACTIVE_CONTEXT_ID`='0', `ACTIVE_CONTEXT_EXTERNAL`='0', `ACTIVE_CONTEXT_UPDATED`=NULL, `ACTIVE_CONTEXT_HISTORY`=NULL, `COLOR`='' WHERE ID = '6'
Backtrace
#0 /var/www/lib/mysqli.class.php(396): custom_error->__construct('1048: Column 'I...', 0)
#1 /var/www/lib/mysqli.class.php(185): mysql->Error('UPDATE `users` ...', 0)
#2 /var/www/lib/mysqli.class.php(294): mysql->Exec('UPDATE `users` ...')
#3 /var/www/lib/sqlFunctions.class.php(129): mysql->Update('users', Array, 'ID')
#4 /var/www/modules/users/users_edit.inc.php(73): SQLUpdate('users', Array)
#5 /var/www/modules/users/users.class.php(168): require('/var/www/module...')
#6 /var/www/modules/users/users.class.php(128): users->edit_users(Array, '6')
#7 /var/www/modules/users/users.class.php(90): users->admin(Array)
#8 /var/www/lib/jTemplate.class.php(713) : eval()'d code(8): users->run()
#9 /var/www/lib/jTemplate.class.php(713): eval()
#10 /var/www/lib/jTemplate.class.php(195): jTemplate->parseModules('...', Array, './templates/')
#11 /var/www/lib/jTemplate.class.php(109): jTemplate->parse('...', Array, './templates/')
#12 /var/www/lib/parser.class.php(93): jTemplate->__construct('./templates/pan...', Array, Object(panel))
#13 /var/www/lib/parser.class.php(63): parser->jtemplate_parse('./templates/pan...', Array)
#14 /var/www/modules/panel.class.php(180): parser->__construct('./templates/pan...', Array, Object(panel))
#15 /var/www/admin.php(34): panel->run()
#16 {main}
Error
Details
Backtrace
#1 /var/www/lib/mysqli.class.php(296): mysql->Error('UPDATE `users` ...')
#2 /var/www/lib/sqlFunctions.class.php(129): mysql->Update('users', Array, 'ID')
#3 /var/www/modules/users/users_edit.inc.php(73): SQLUpdate('users', Array)
#4 /var/www/modules/users/users.class.php(168): require('/var/www/module...')
#5 /var/www/modules/users/users.class.php(128): users->edit_users(Array, '6')
#6 /var/www/modules/users/users.class.php(90): users->admin(Array)
#7 /var/www/lib/jTemplate.class.php(713) : eval()'d code(8): users->run()
#8 /var/www/lib/jTemplate.class.php(713): eval()
#9 /var/www/lib/jTemplate.class.php(195): jTemplate->parseModules('...', Array, './templates/')
#10 /var/www/lib/jTemplate.class.php(109): jTemplate->parse('...', Array, './templates/')
#11 /var/www/lib/parser.class.php(93): jTemplate->__construct('./templates/pan...', Array, Object(panel))
#12 /var/www/lib/parser.class.php(63): parser->jtemplate_parse('./templates/pan...', Array)
#13 /var/www/modules/panel.class.php(180): parser->__construct('./templates/pan...', Array, Object(panel))
#14 /var/www/admin.php(34): panel->run()
#15 {main}
Что это значит и как поправить?
Изменения при редактировании пользователя не сохраняются ,связать пользователя с объектом не мону.
