andrey040670
Сообщение andrey040670 »
Останови cycle_bluetooth и удали если будет сам стартовать.
alexpzas
Сообщение alexpzas »
andrey040670 писал(а): Вс янв 13, 2019 8:17 pm Команда
sudo startx
что говорит?
pi@MajorDoMoPi3_33:~ $ sudo startx
xauth: file /root/.Xauthority does not exist
X.Org X Server 1.19.2
Release Date: 2017-03-02
X Protocol Version 11, Revision 0
Build Operating System: Linux 4.9.41-v7+ armv7l Raspbian
Current Operating System: Linux MajorDoMoPi3_33 4.14.50-v7+ #1122 SMP Tue Jun 19 12:26:26 BST 2018 armv7l
Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight= 416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 d wc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=122680e3-02 rootfstype=ext4 elevator=deadline fsck.mode=force fsck.repair=yes rootwait
Build Date: 18 October 2017 04:55:30PM
xorg-server 2:1.19.2-1+rpt1+deb9u2 (https://www.debian.org/support)
Current version of pixman: 0.34.0
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Sun Jan 13 20:57:32 2019
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
(EE)
Fatal server error:
(EE) no screens found(EE)
(EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
(EE) Please also check the log file at "/var/log/Xorg.0.log" for additional info rmation.
(EE)
(EE) Server terminated with error (1). Closing log file.
xinit: giving up
xinit: unable to connect to X server: Connection refused
xinit: server error
andrey040670
Не установлен "рабочий стол" хотя дисплэйный меннеджер установлен, что странно и x server тоже в наличии.
Установите любое окружение рабочего стола на свой вкус, например LXDE или родное raspbian'овское PIXEL
Или вот на выбор: https://linuxconfig.org/8-best-ubuntu-d ... aver-linux
viktor6
Сообщение viktor6 »
Ребята кто-то пробовал установить образ 3.34 на raspberry pi 3 B? Я вот установил и всё работает.
andrey040670
Ничего удивительного. Raspbian Stretch от разработчика (www.raspberrypi.org) универсальный.
woow
Сообщение woow »
вот это уже совсем не нравится, лог файлы стёр циклы с бле и бт все остановил, приложение деинсталировал, что ещё где убрать, сегодня результат тот-же:
/var/www/cms/debmes/
log_2019-01-14-cycle_bluetooth.php.txt 3.553.168KB
Но кроме этого не могу зайти в панель управления (ни какие свои пасворды не прописывал)
Raspberry Pi 3B+
madbob
Сообщение madbob »
woow писал(а): Вт янв 15, 2019 8:32 pm
Я тоже не прописывал. Попробуй admin admin. У меня подошло. Хотя, конечно, не дело это...
Raspberry Pi 3 образ 3.31+GUI ESP12(IoT)кучка+ESP32
andrey040670
Проверьте config.php, а цыклы надо удалить (папка scripts), модуля нет, а цыкл стартует.
По поводу админки, у Вас малина не торчит во внешней сети?
woow
Сообщение woow »
andrey040670 писал(а): Вт янв 15, 2019 9:17 pm Проверьте config.php, а цыклы надо удалить (папка scripts), модуля нет, а цыкл стартует.
ну ладна спасибо с вашей помощью удалил цикл, но всё таки не ясно из за чего он так раздулся. config.php ни когда не трогал открыл пока не знаю что там ковырять.
Raspberry Pi 3B+
andrey040670
Ну так в логе и написано, и ещё я бы вам посоветовал бы разобрать логи из var/log/ там быстрее поймёте в чём у вас проблема.
